1 - 1 of 1 Posts
I'm going a brake conversion on my 2010 (using 2014-2016 Police brakes). The early cars use 12mm bolts to mount the caliper bracket to the upright, the cop cars use 14mm - I'm guessing this is part of the 2014 changes.
Does anyone know if the later upright will physically interchange with the early upright? I'm hoping the ball joints and other connections are all the same. If not, then I use steel inserts to fix the bolt hole difference.
1 - 1 of 1 Posts
