1 - 11 of 11 Posts
2010 R/T Classic 6M
Does anyone know where I can find a replacement fuel line retaining clip that holds to hose to the pump. Mine broke when I swapped in the API pump and I've been using a cheap dorman one that works but I don't trust especially since it's a different style clip.
2010 R/T Classic 6M
Discussion Starter · #2 ·
No one has any idea where to find this clip? Autozone sells one for every brand except dodge. I can't even find the fuel hose if I wanted to replace the whole thing.
2018 Billet SXT Plus
The clip, as you probably already know is serviced with the line. From the looks of it the line is not all that expensive.
Worst case scenario, just buy the line, if you cant find the clip aftermarket.
2010 R/T Classic 6M
Discussion Starter · #5 ·
You found the line? Only place I saw it was with the whole fuel sending unit/regulator, which is for some reason a discountinued part from Mopar.
2010 R/T Classic 6M
Discussion Starter · #7 ·
Nope not it, that's what I thought too. It's more of a hose than a line. I marked the connection and where it connects to.
1002894
2019 Dodge Challenger RT
Hey @JD40, I've got a similar situation brewing. What did you end up going with?
2010 R/T Classic 6M
Discussion Starter · #11 ·
For about 8-9 months now Ive been using a different (wrong) style clip that they had at AutoZone. Obviously I've had no issues since
1 - 11 of 11 Posts
