Hi guys! Have a problem with fuel sensor... Shows me the wrong distance when I refuel. Does anyone know where to start and where is the sensor? What's the best thing to do first?
Mobile phone Telephony Communication Device Mobile device Portable communications device
The info at this link may be of some value to you:
Could be the sensor. But it could be the pump that transfers fuel from one side to the other side. The sensor is just doing its job and noting the fuel level is not what it should be.
Thanks! Maybe, You know the location of sensor? Maybe some scheme?
'16 A8 Scat Pack
You bet. I had this issue on a '10. New OEM factory pump assembly, problem solved.
A handful of folks here have had this happen. Not common or a big problem, but a PITA for those who get a bad one.
Of those folks, several had issues with aftermarket assemblies. If possible, buy a new unit from a dealer or on line dealer.
Best of luck
