6.1 HEMI Stage 1 Ported Intake Manifold
BUY the Stage 1 Ported Intake Manifold and SELL us your stock 6.1 intake for $500!!
Limited Supply Available!
UPGRADE your 6.1 HEMI or 5.7 Eagle on a budget.
BUY IT NOW for $1,250 - including core charge!!!
Call now - 866.844.1245
Upgrade your 6.1 HEMI or 5.7 Eagle on a budget. The throat of the ported intake manifold is opened to match our 90 mm HEMI throttle body.
The Ports are port matched with Arrington ported heads, and the fuel injector bosses are reworked.
All these modifications were designed and tested by our top HEMI engine builders and are performed by the HEMI engine builders using a combination of CNC milling and hand work for the best possible air flow in your Custom Ported Stage 1 and Stage 2 HEMI Intake Manifolds.
General Specifications:
- Direct, Bolt on Replacement for 2005 – 2009 HEMI 6.1
- Fits under stock hood Precision Cast aluminum
- Full 90mm bore
- Hand Worked and CNC Milled in the USA
- Port Matched to Arrington Ported Heads
* Core Purchase offer is on usable cores valid from 90 days from date of shipment. Core purchase form is required for payment.
A 15% restocking fee on all returns. Returns will not be accepted without prior authorization. Refund subject to change upon inspection of return item.
Electrical items are not returnable.
