1 - 3 of 3 Posts
Since I upgraded my wheels from factory 235/55/18 to 265/35/22, should I upgrade my cars programing?
If I don't update the program, my the transmission shift points should change? I'm I correct?
If you use the tire rack website you can calculate the OP of each tire. If the OD is closer no need to change. I went from 18 to 20 on my 2010 and it was less then 1 mph difference. At most your 2 mph off
1 - 3 of 3 Posts
