1 - 11 of 11 Posts
We have these ready to ship ... makes a great Christmas gift!!
GoPro’s HD Motorsports HERO is the world’s highest performance 1080p HD on-board video and still photo camera. Professional quality 1080p, 960p, and 720p HD resolutions record at 30 frames per second (60 fps in 720p). The HD Motorsports HERO easily mounts to any helmet, motorcycle, ATV, car, plane, jet ski, boat, snowmobile or other vehicle. The camera’s quick-release mounting design makes it easy to re-position the camera around your vehicle for professional quality HD video from several angles.
To order: GoPro HD Sports Hero Camera
Record up to 2.5 hours on a single charge and up to 9 hours total on a 32GB SD card (not included).
Included are mounts for two helmets and three vehicles, as well as a suction cup for maximum versatility and convenience. The housing is waterproof to 180’ / 60m.
GoPro's obsession with sound has conquered the wind. At 85 mph on a motorcycle, you’ll enjoy the throaty sound of your motor, not the wind. Inside even the quietest street cars, hear the pull of your motor...not the drone of the wind and road.
Included is a 1100mAh rechargeable lithium-ion battery that lasts for up to 2.5 hours of constant recording. With optional accessories, you can also plug the camera into a wall outlet, cigarette lighter, or with any USB-compatible power adapter, wire it directly to your vehicle’s electrical system. The battery will charge while you record.
The camera can also shoot automatic 5MP photos at 2/5/10/30 and 60 second intervals during your drive or ride, hands free. Press the shutter button once and record up to 2.5 hours of poster-print quality photos.
Waterproof to 180’ / 60m and protected from rocks and other hazards thanks to its removable polycarbonate housing. Replacement housings and lens kits are available, making repairs or refurbishing your HD HERO camera affordable and convenient. It's a GoPro...go for it.™
What's Included:
1 HD HERO Camera (5 megapixel)
1 Rechargable 1100 mAh Lithium-Ion Battery
1 Waterproof Quick-Release Housing (180’/60 m)
3 Flat, 3M™ Adhesive Mounts
2 Curved, 3M™ Adhesive Mounts
2 Quick-Release Buckles
1 Vertical Surface “J-Hook” Buckle
1 Suction Cup Mount
1 Three-Way Pivoting Side Arm Assembly
1 USB Cable
1 Component Video (HDTV) Cable
1 Composite Video + Audio Out Cable
Warranty: One Year
Tech Specs:
Camera Optics
Lens Type: Fixed Focus (2ft/.6m – ∞), glass
Aperture: f/2.8 (high performance in low-light situations)
Angle of View: 170º ultra wide angle in WVGA, 720p, or 960p mode
Angle of View: 127º wide angle in 1080p mode
Video
HD Video Resolution Modes: (subject to change, pending final firmware release)
1080p = 1920x1080 pixels (16:9), 30 fps, 15 Mbit/s data rate
960p = 1280x960 pixels (4:3), 30 fps, 12 Mbit/s data rate
720p = 1280x720 pixels (16:9), 60 fps, 15 Mbit/s data rate
720p = 1280x720 pixels (16:9), 30 fps, 8 Mbit/s data rate
WVGA = 848x480 pixels (16:9), 60 fps, 8 Mbit/s data rate
Sensor Type: 1/2.5" HD CMOS, 2.2µm-sized pixels
Light Sensitivity: Super low-light sensitivity (>1.4 V/lux-sec)
Video Format: H.264 compression, saved as Windows- & Mac-compatible MPEG4 (.mp4) file
Exposure Control: Auto with user selectable center weighted average and spot metering settings
White Balance: Auto
Audio
Microphone: Built-in, mono with AGC (automatic gain control)
Audio Format: 48 kHz, AAC audio compression
Resolution: 5 megapixel
Capture Modes: Single shot, photo every 2, 5, 10, 30 or 60 secs.; 3 photo burst; self-timer
Storage
Memory: SD card, up to 32GB capacity (SDHC)
Average recording times (using 32GB SD card):
1080p (30 fps): 4h 21m
960p (30 fps): 5h 26m
720p (60 fps): 4h 21
720p (30 fps): 8h 09m
WVGA (60 fps): 8h 09m
Camera Connectors & Cables
PC Connection: USB 2.0 (data connection and battery charging)
HDTV Out: HD NTSC & PAL (component cable incl.)
Audio Out: Combo 2.5mm jack with stereo audio and composite video out
PC Compatibility: Windows® Vista or Windows® 7; Mac OS® X 10.4.11 and later
Power & Battery
Battery Type: Rechargeable 1100 mAh lithium-ion
Battery Life: Approx. 2.5 hrs
Charging: via USB to computer or optional power adapter
Charge Time: 80% capacity after 1 hour with optional power adapter; or 2 hours with a computer’s USB port
Waterproof Camera Housing
Depth Rating: Up to 180 feet / 60 meters
Construction: Polycarbonate and stainless steel
Hardware: Stainless steel
Size & Weight
Dimensions (H x W x D): 1.6” x 2.4” x 1.2” (42mm x 60mm x 30mm)
Weight: 3.3oz (94g) incl. battery, 5.9oz (167g) incl. housing
How well do they stay on the car? lol I'd like to get one to mount on the car for track use..but it would suck if it were to fall off going down the track!
you could do that easily.
look at my videos. all GoPro recorded. But don't forget to switch to HD mode on youtube to enjoy the full quality...
Chris these things are supposed to be awesome. Lukester has one, and uses it for any videos you see come from his way. I haven't gotten a chance to mess with one in person yet, but from everything I hear its the only way to go if you're considering a car cam. Apparently capture exhaust audio perfectly too... I'm probably gonna grab one eventually.
edit: beat me too it haha.
Thanks guys! Looks like I might be investing in one soon! $288 is a great deal for all you get
BTW-Awesome videos!
Yeah they are really great! We have several customers running them and a good friend uses his all the time at VIR with his Marauder. Can't beat it for the price and it can be mounted anywhere!
guys. just make sure you put a big flash disk into it as well as having a powerful computer at home.
HD video is consuming a lot of resources when cutting it.
but any actual Mac will handle it with ease ... ;-)
Needa get my MacBook fixed, battery crapped out and the charger did as well..hope thats the only problems lol
...but any actual Mac will handle it with ease ... ;-)
Lucian, which video editing program are you using? I couldn't import my GoPro HD movie into iMovie08. I had to save the file, convert it to MP3, then import into iMovie08. It doesn't appear iMovie08 supports MP4 video.
Hmm, iMovie ought to handle MPEG-4. It's practically an Apple invention. MPEG-4 is partially based on Apple's QuickTime Movie format.
Great videos, Lukester! I definitely liked your use of instant replay in the first movie.
I'm using iMovie 11. clean and simple which automatically detects this GoProHD once you plumb it to your Mac via USB..
Was using this iMovie 10 before where you had to manually import the files of the flash disc. But still easy going.
1 - 11 of 11 Posts
