Been looking into getting a wideband for tuning, but I wanted to know how most people got their afr readings on to tt dyno. I know you can record data with the lc-1 kit, but i'm looking into getting the c2 autometer gauges. Can I record afr readings with this wideband gauge and put it onto tt dyno?
The answer is no. TT Dyno can't read the data from my LC-1 either.
I tried to find a way around this, but the problem is the time stamps. The logs are just timed entries, nothing more nothing less. Since the readings are from two different sources, TT Dyno can't match them up.
The solution is to get a Wideband that has analog outputs. You can hook one of those to a Dialbo Trinity and record the AFR as a PID along with your others. TT Dyno will then be able to read the AFR with the run.
From memory I don't think the Autometer wide bands have analog outputs but double check me on that.
Discussion Starter · #4 ·
Thanks Speedy!!
I use an Innovate LM-1 wideband meter. It also has the analog out that I feed into the analog input in my trinity. then I can log the afr along with my other PIDS
