1 - 3 of 3 Posts
GROUP BUY: Stack Performance 'BULLET" Cold Air Intake System (Spring Festival special
GROUP BUY/NEW PRODUCT: SP "Bullet" Fresh Air Intake system
We are offering another Group Buy on our "Bullet" Fresh Air Intake system.
We have taken time to design our cold air intake system to perform to “our” standards. Our intake system is designed to draw actual cold air from a source outside of the hot engine bay.
Cold air provides more oxygen for the engine to burn. Cooler air has a higher density (greater mass per unit volume), thus cold air intakes generally perform by introducing cooler air from a point outside of the hot engine bay.
The term "cold air intake" is often used to describe other methods of increasing oxygen to an engine, which may even increase the temperature of the air coming into an engine. The true name for these intakes is “Ram Air Intake”. Do not be fooled.In designing and engineering our cold air intake system, we have used these strategies to obtain our required level of performance:
• Increased the diameter of the air intake, providing increased airflow.
• Smooth interior of the intake tube, reducing air resistance.
• Engineered tube shape to offer a more direct route to the intake manifold.
• Tuned the length of the intake tube to provide maximum airflow at certain engine speeds and RPMs.
• A more efficient, hi-flow air filter with open end element.
• Cold air provides more oxygen for the engine to burn.
Our tube uses 3.5" inlet, then gradually increases to 4.18", (just over 90mm) then kicks to 4" at the throttle body. This design increases velocity, which increases HP/TQ and throttle response.
This system is plug and play. (5.7L Challengers will extending your existing harness. Wire and detailed instructions are included)
Group Buy price: $289 + shipping
Please order by using this link:
Challenger Intake, Charger Intake, 300C Intake
Pre-Filters are also available for $24.99, just click on the option to add to your order.
In stock and will ship within 72 hours. If we sell out, we will still honor the GB price and keep your name on the list in the order received. We are continuously producing these kits, so the wait should not be long if we backorder.
Group Buy price ends March 26th.
(if you will be attending the Spring Festival, we can have it there for pick-up) it will need to be paid in full and you'll need to let us know you'll be picking it up at the show.)
This image has been resized. Click this bar to view the full image.
Any additional pictures?
Where does the filter come out? Can you post pictures of the filter end installed? I would like to see where it ends up and understand how difficult it is to install.
You could simply PM me with the requested pics and info
Scott
Thanks
Thanks Tim and Ryan for the phone assists. Recieved and installed, love the feel and the look!:thumbsup:
Rex
1 - 3 of 3 Posts
