I got 17 x 10 Weld with 275/50R/17 M&H mounted . They fit fine on the passenger side once weight it on the tire with about a finger of clearance between rim and sway bar . But had to jack up the supension just to bolt up the wheel on driver side with another jack under the body . Then let the body down. Sway bar was hitting the rim. Never put it on the ground as I got sick and dizzy . Ended up putting factory wheel back on to put the car back on the floor. Sure hope it clears when I check it again . But don't think it will clear .
Ended up having wife take me to hospital . But everything ok .
