1 - 17 of 17 Posts
I am curious if an R/T hood has enough height to clear a hellcat supercharger? Has anyone tried this swap before? I know its usually the other way around with people putting the more aggressive-looking Hellcat hoods on their cars, but I'm trying to determine if it will work the other way around before going to the junkyard and dropping $400 on a used hood just to test it.
2011 SXT
There is a guy in a Local Car Club that did that to his Hellcat but I could not tell if he modified it but he did that to keep a more Stealth look to his Hellcat and removed all the Badging.
2018 Hellcat. 2017 Scatpack.
the question is..why? :unsure:
Dodge spent alot of time, effort, research, testing & $$ into that hood design - specific for what the hellcat needs in regards to air in / air out, its far from simply looking more agressive..those heat extractors and forward positioned center scoop are there for very good reason. The R/T hood design has very limited "flow" by comparision.
Seems like a backwards move in several ways.
Reactions: SFCR
2011 RT Classic Bright White
I’ll swap you.. let me know when your here. Just honk.
Discussion Starter · #6 ·
This answer will likely only inspire more questions but here goes: It is because the GMC 6-71 Supercharger I am mating to the top clamshell of my existing Hellcat supercharger requires a large penetration to be cut through the hood for clearance and the R/T hood with its flatter profile would work better aesthetically. There ya go.
Pictures please when it’s done!
I do not think you will gain any added clearance swapping hods, center 'bulge" on both hoods appear to be very close in hieght.
Perhaps the demon hood may be better suited ( dont have one handy to check, sorry) and I do recall seeing an aftermarket version that had more built in clearance.
One thing I noticed right away after moving from my Hellcat to my Scat Pack is I saw "less" hood when looking out the Scat Pack windshield. That Hellcat hood may not look like it but it has some "bulge" in it to clear the supercharger.
2016 Scat Pack M6
Bob, where do you live and what color car do you have? I think local members with R/T's may be open to trade. I know I would.
BOB.....I never saw a location for you.......I've got a stock '09 Deep Water Blue hood taking up space in my wellhouse. I'm in southern Illinois, so you figure out if it's close enough to you to use.....(I replaced it with an early T/A hood and probably won't ever put it back on....) We can work out a good price.....
Discussion Starter · #17 ·
Sounds like just what I am looking for, alas am in Floridia though. Were I closer I would definitely discuss, but thanks for the offer!
1 - 17 of 17 Posts
