Ohio-Speed now has special pricing for CT Members only on this Hawk Brake Kit!
2009 2013 Dodge Challenger Hawk Performance HPS Brake Pad and Rotor Kit (Front) HKF8359507
Hawk Performance HPS brake pads are designed to ensure performance, safety, and quality on the street.
Combine them with Hawk Quiet Slot rotors and you have braking at its best for your street machine!
Their HPS brake pad and rotor kits feature their high performance street pads with a unique ferro-carbon compound that blends the safety and quality of aerospace design with the severe-duty friction technology of motorsports.
The kits also feature their specifically engineered rotors cast from premium alloys with a unique slot design and Geomet plating that provides virtually quiet, dust-free performance you can rely on.
When it comes to high performance on the street, you can count on Hawk Performance HPS brake pad and rotor kits.
Brake Rotor and Pad Location:Front
Intended for Street Use:Yes
For Use with Stock Calipers:Yes
Rotor Style:Slotted surface
Front Rotor Outside Diameter (in):12.600 in.
Front Rotor Thickness (in):1.102 in.
Rotor Material:Carbon iron
Rotor Finish:Geomet coated
Brake Pad Material:Ferro-carbon
Friction Material Type:HPS
Brake Pad Construction:Integrally molded without shims
Electronic Wear Sensor:No
Quantity:Sold as a kit.
2009 2013 Dodge Challenger Hawk Performance HPS Brake Pad and Rotor Kit (Rear) HKF8362508T2
Brake Rotor and Pad Location:Rear
Rear Rotor Outside Diameter (in):12.600 in.
Rear Rotor Thickness (in):0.870 in.
PM FOR OUR CT MEMBERS ONLY PRICING!
