1 - 2 of 2 Posts
Stainless are no good as they are a grade 2 however you could get a 17-4 ph 17-4
Precipitation Hardening also known as Type 630 is a chromium-copper precipitation hardening stainless steel used for applications requiring high strength and a moderate level of corrosion resistance. High strength is maintained to approximately 600 degrees Fahrenheit (316 degrees Celsius).
General Properties
Alloy 17-4 PH is a precipitation hardening martensitic stainless steel with Cu and Nb/Cb additions. The grade combines high strength, hardness (up to 572°F / 300°C), and corrosion resistance.
Sorry I can't remember it is either grade 5 or 8 and has good anti corrosion properties.
1 - 2 of 2 Posts
