My headlight really need to come down on the passenger side. At 25' it's about 8" higher than the drivers side.
I found the "up and down" gear/screw and when turning them the lights move from the pressure of the screwdriver, but neither headlight moves up or down no matter how much I turn the "gear".
I have searched the net and this forum but have found nothing about the headlight adjusters (other than the auto light sensor) so any help would be great.
Thanks,
Frank :scratchhead:
If its anything like my ram was, its a Torx head that you need
Drivers side is always lower so you don't blind oncoming traffic.
I would really like to know this as well. Seems mine are set too low.
Follow up-
It was warm today so I had a chance to play a bit. The directions on the panel above the headlights are backwards. You can reach in behind/under the panel to get to the adjuster and turn it by hand or simply pop the panel off and see everything. It takes a lot of turning but the adjusters do move the beam up and down.
