1 - 1 of 1 Posts
I have been looking at the connector drawing for a 2015 and up headlight, that a member here posted. I noticed one of the pins is a fault sensor. Does someone here know how it works? Possible parameters?
I ask because a year or so back, I tried splicing a second light (LED) into my side markers. (Power and ground wires from LED to power and ground wires for side marker) That process tripped something, and the headlight started going crazy flickering/ going out etc. I removed the splice and everything works fine.
I see extra slots in the connector for grounds etc, and am curious how to bypass the fault sensor, or find the parameters to attempt to work within them.
Thanks for your time.
Chuck
1 - 1 of 1 Posts
