I'm in a 2016 Challenger Hellcat. I'm thinking about doing a pulley swap. (pure stock right now) I know very little about it. I'm not sure if there are different levels? If so, I don't want to go extreme, so, say between mid level and max possible. What I'd like to know, is a parts list/cost, labor/cost and what gains...listed out like below.
1) Pulley(s) pn 123, $100?
2) belt abc $50?
3) Id rather NOT have to do a Tune, only If I Have to, then I'd get a 2nd PCM $???
4) Labor $$$
Whats the horsepower gain?
(I'm at 34000 miles, warranty is done, at 36K, so I'm good there, but, still like to keep it as low maintenance as possible)
Have you checked the hellcat forum?
YEah I saw that........a LOT of talking and not saying that much. I'm looking for a part list, cost, and gains. Below is what I have so far: (keep in mind I want to stay conservative on this). I think this is a complete list. now, the cost? and what HP and PSI gains?
>HP Tuners MPVI2 with 2 credits
>PCM tuning with optional TCM tuning
>Seperate Unlocked PCM (core charge may be available for factory PCM)
>Metco 3.1" - 2.85" upper pulley kit (or hellraiser 2.85 pulley ??)
>Gates HD belt
>180° Thermostat (I already have this)
>Crank pin & related parts - this step is critical and many do not perform this modification.
Catastrophic engine failure can result if your crank is not pinned.
I am not up to speed on the HC but for boosted R/T and SP gains are ~20HP per 1psi boost. I'd say biggest cost is HP tuners ($299)+credits ($200)+PCM ($250 to have original unlocked or $899 for a new unlocked one)+tune (anywhere from $400 to +$1000 if dyno tuned). BTW TCM tuning requires 4 credits (~$200). You most likely will need a tune seeing as the HC has a boost controller. Not sure if the MAF (2015-2016 used a MAF) has to be messed with?
For pulleys I used this guy. Although not sure if he has pulleys for a HC blower but might not hurt to see if he can make them on the cheap?
Good luck and hope someone more knowledgeable chimes in.
HHP does kits
If nothing else they list belts and such
Ripatuned Pumpgas killer + 1050s + tune. Simple enough, and probably the most mild "bang for your buck" way.
