1 - 11 of 11 Posts
2016 Dodge Challenger Scatpack Torred
Hello everyone,
One of my friends is offering me his hellcat Rotating Assembly including crank (previously pinned), pistons, rods and rings.
From what I hear they fit in a 392 without problem. I would like to do a supercharger, if this will help the 392 stay more stable after application. Many suggest a new bottom end as well, but I hear it's unnecessary.
What are your thoughts on this?
Thank you!
the 6.2 and 6.4 block are dimensionally the same
Thanks Steve. What type of work is needed to swap this out, and will this help me get more stability while under high boost?
Thanks again.
Thanks Luke. What type of work is needed to swap this out, and will this help me get more stability while under high boost?
Thanks again.
Fixed that for you ;)
in theory, same bore, light hone, and assemble, however would verify all specifications, putting a 6.2 rotating assembly in a 6.4 will result is 6.2L and vice versa
personally not a fan of used parts, but on a budget not a bad idea
What would your shop charge for a job like this? Do I need any additional parts?
would not do it
we warranty our work, cant warranty used parts
1 - 11 of 11 Posts
