I bought some nice engine half covers from Steve White Motors for my R/T, and I'm trying to determine the best short-term workaround for fitment. The passenger-side cover keeps popping off due to the vent hose out of the PCV.
I know that the obvious answer is install a catch can to re-route the lines in and out, but I'm not ready to pull the trigger on that. I have the silencer-style air inlet tube and need to replace that before I can do the proper Z-bracket mount---and I just don't want to spend the $200+ dollars quite yet. Good grief, I spent almost that much on the engine covers and didn't fully realize that I'd have this fitment challenge. :icon_confused:
Is the best short-term solution just to source some soft hose to replace the factory-installed hard fittings & hose?
From what I've heard these need to be trimmed to fit properly around some engine parts.
Yes. I have lopped/Dremeled-off a standoff on the driver-side cover, so that's all good. I went ahead and Dremeled-out more of the curved area along the top straight-edge portion of the passenger-side cover in an attempt to remove enough material to pass the vent tube cleanly, but no go.
Keep the original in place until you get the CAI and catch can.
That is a cheap, and quick short term fitment. Sorted. ;)
I know that the obvious answer is install a catch can to re-route the lines in and out, but I'm not ready to pull the trigger on that. I have the silencer-style air inlet tube and need to replace that before I can do the proper Z-bracket mount---and I just don't want to spend the $200+ dollars quite yet. Good grief---I spent almost that much on the engine covers and didn't fully realize that I'd have this fitment challenge. :icon_confused:
I bought a five dollar piece of flexible tubing and used that to route under the cover.
Justin
I think that someone posted that if you squeeze the PCV hose under the fuel cross over, it will fit better.
Or I could be wrong again!
:bash:
