Okay, so first off - my battery is not dead, I did try jumping it though to verify. And I have tried disconnecting and reconnecting the battery terminals several times.
What is going on is my key fob is stuck in the ignition and the car won't start or show any ignition related activity.
It happened last night when I went to plug my Trinity in to adjust throttle boost (I've used the thing several times before with no problems). I plugged it in and it did it's count to 5 deal and then told me to turn the key to the on position. I did this but the Trinity never started up, it just kept repeating this cycle. I unplugged it and plugged it back in figuring I'd try again - this time the Trinity wouldn't turn on at all nor would any ignition related activity appear on the EVIC ... and the car wouldn't start. I took the Trinity inside and plugged it into my laptop to make sure it wasn't fried. It's not it started right up.
In the car, the headlights, horn, interior lights, and non ignition related EVIC messages like "door ajar" work. But the car will not turn on. After disconnecting and reconnecting the battery the EVIC popped up a message saying to "press brake and push start button to start". My push button is sitting in the cup holder but I pressed the brake and rotated the key clockwise to try and start it.
I don't know if this is a coincidence that this happened while trying to use the Trinity or if it is just a failed part. Who knows - I'll be calling the dealer when they open though.
Does anybody have any suggestions for me or have you guys had a similar experience?
