1 - 15 of 15 Posts
pic of hood
went to pick car up from a reputable shop and this is what I found. they were helpful and willing to fix but my ride had already left 20 min prior. hoping someone here has a suggestion for a fix. I already tried the adjustment bolt with the plastic head. no luck. also tried the front bump stops, again nothing.
2021 F8 Green Scat Pack Shaker
pic of hood
Take it back and have them fix it.
theres an adjuster with a hex end on the hinge - you access it with the hood open and it can lower / raise the back edge in relation to the fender
Reactions: Bob Ricewasser
Discussion Starter · #4 ·
Correct, it’s a plastic nut on a threaded rod. I have adjusted both sides with no luck. It’s gotta be deeper, like a bent qtr panel or hood hinge is compromised just slightly enough to offset. I just spent and hour and a half sweating my ass off trying to make the adjustments and had no luck whatsoever
It’s not a body shop, fear letting them “fix it” will not be anymore then a new mess to deal with. Plus don’t want it rigged
2019 Sublime Shaker, 2010 Plum Crazy R/T Classic, 2010 Detonator Yellow R/T Classic
The hinge itself needs to be lowered. I have done this a few times, they build some play into it, to make adjustments. The "plastic nut" in the front, really does not do anything.
Discussion Starter · #6 ·
I’m specifically referencing having already tried the plastic nuts and threaded screw on the hinge by windshield (not the plastic bump stops towards the front bumper). Spend 2 hours yesterday and got nowhere.
I assume the hood was fine prior to this? Did the shop work in the engine compartment? Maybe they left a tool under the hood or a loose part that is keeping the hood from closing properly. The photo suggests a significant difference that would be pretty hard to "adjust out".
If they damaged it and will accept responsibility they should have it fixed by a qualified body shop. If they are not qualified or you don't trust them it should go to someone who is.
What kind of shop was it? What were they working on?
I am having trouble with a body shop that did not complete a repair. I have already filed a complaint with the BBB. If that does not produce action a social media blitz campaign is next.
Discussion Starter · #9 ·
had them do a full once over on the build and check for anything they may see as an issue for a boost lag i was getting. they didnt turn any wrenches at all. i trust they didnt do anything intentional, accidental or without noticing is another story. i need a fix boys.
i swear all around the country sh*t is falling apart. its like NO ONE can properly do ANY job anymore. feel your pain bro, right in the hood. hahaha
Thank God! I thought I was the only one that felt that way. Pride in doing a job well done is disappearing. Just recently, I have had shops turn me away because the job was "just to difficult", read "pain in the a**". Or because they just wouldn't make enough money, read "rip you off". It truly is disheartening! And at a time when I am getting too old to do it myself! :mad:
what bout bolts on hinge to the body ? loosen rear one and pivot it down to pull hood corner down
You did not answer the question.
Was the hood fine prior to them touching the car?
2016 Challenger R/T Scat Pack Pitch Black A8
Was the hood like that when you took it in? If it wasn't they must have done something to cause it. Or, did you have the hood off working on it and maybe leave a bolt loose?
2008 Challenger SRT8 #1101. 2005 Dodge Magnum RT AWD
I have a shop working on my Magnum (Daily driver). There are 8 clips (4 on each side of the windshield holding trim/gasket pieces.
I already have the new trim and clips and they quoted me $208 to replace them. 4hrs estimate to drill out 8 pop-rivets and reinstall the new ones. They even come with the rivets to do this!
Wood Fixture Gas Font Metal
Font Auto part Automotive tire Brand Label
Ridiculous.
$200 for 4 hours labor (it won't take that long) is pretty cheap. All the shops in my area are $100+/hr. So, still not that outrageous.
1 - 15 of 15 Posts
