You don't want to run too lean,could cause engine damage under load.Sounds like the tune needs adjustment,probably causing both codes.procharged stage2
p0171- lean bank 1
p0300- multiple cylinder misfire
p.s the map im running is very conservative until the weather breaks in march when i can get it dyno tuned. the question is do i have to worry about p0171
