1 - 2 of 2 Posts
Well I was going to put the car away for the winter. I got the oil changed and brought it home. I was going to take the wheels off and clean them. Well I was using a pinch weld adapter sitting in my cup on my jack stand. Well I jacked the back of the car up and one of the rocker molding clips came undone. After applying pressure, smacking it with my hand, tapping it with a rubber mallot the one clip will not re clip. Is there a trick? I hope so. BTW it is a 2015.
Thanks.
Discussion Starter #2
Shheeeeze after I calmed down I went out and looked at it, I noticed underneath the bottom was pushed up next to the pinch weld. After prying it down with my fingers, the top went right in place....... I am such a panic stricken moron.....
1 - 2 of 2 Posts
