Yikes... Thats tricky. Yea u def dont wanna pull of that pinstripe if its under the clear coat. Unless u wanna repaint the panels the stripe is on. Why someone would clearcoat over a pinstripe is beyond me...
That appears to be an aftermarket pin stripe. Can you feel the edges with your fingernails? If so, it's probably not clearcoated and I'd get a second opinion from another shop. I agree with prior comments on why someone would clearcoat a decal? Are you sure those pinstripes are not painted on? If they are, you'll have to have them professionally removed.
Yeah it's dipped. And thanksDid you plastidip the wheels? I like the look.
Wouldn't hurt going to another shop to get another opinion. You may get lucky and the other place didn't know what they were talking about.
You don't have tons of options here, you try to dig out the old stuff you going to leave a crater. If the new stripes cover the current ones they could spray clear into the crater left by the old stripe till it high enough to wetsand level. Then once your stripes are on it will cover where this was done. If you want it done right both side will need to be recleared after the old stripe is dug out, EXPENSIVE.
IF, they really did clear over the current stripe you MIGHT be able just to try to level it by wetsanding, leaving the old stripe embedded where it's at and putting your new stripe over the top (again assuming it covers).
Seems like a lot of $$$ to drop for a stripe on a V6 car if he has to repaint the whole car just to put some other stripe back on. Think you need to learn to like what you have.ugh. tough one man.
if you were looking to get a new paint job or vinyl wrap it, this might be your excuse to do it now.
hope you find a solution.
That fact that it's a V6 (if it is) has no bearing on anything whatsoever. And he's already made it clear the new stripes will be a different style.Seems like a lot of $$$ to drop for a stripe on a V6 car if he has to repaint the whole car just to put some other stripe back on. Think you need to learn to like what you have.
So what? Is it worth repainting the entire car for some stripes?? He has to decide that, not us but I wouldn't do it, probably cost 1/4 of what the cars worth to do what he wants.That fact that it's a V6 (if it is) has no bearing on anything whatsoever. And he's already made it clear the new stripes will be a different style.
I cleared my painted stripes on my Vette, it protects them and it looks great when it all smooth, not sticking up off the paint. If his stripes were painted on (which is what I suspect) it would add to the pain for him. What I did was shot 2-3 coates of clear, let it dry for a day or 2, wetsanded again and shot 2-3 more coats of clear. Last wetsand leveled everything out smooth which he could do here but the new stripes would need to cover the old ones since they would still be there. Either way, lots of work for little upside IMHO.I hope you find a solution, man. I have no idea why anyone would clear over such a small pinstripe.
