Order your Arrington Performance 90mm Throttle Body from Peak Speed Shop.
The 90mm Arrington Cast Throttle Body is well suited for 5.7 or 6.1 HEMI engine owners who would like extra horsepower without extensive engine upgrades. Installation is a quick bolt up application for better performance. Just unhook intake tube and drive by wire plug, take out the 4 mounting bolts, then reverse those steps to put on the new throttle body. The cast throttle body is engineered and tested by HEMI engine builders for the best results. If you are looking to plant more HEMI power to the ground faster grab this 90mm throttle body today.
Order yours at: Hemi 90mm Cast Throttle Body - Drive by Wire [API-90MMCTB] - $449.99 : Peak Speed Shop, Boosting Horsepower...Adding Style!
Or, call us at 719-651-1952.
