John gets us all to push somehow....I wish I can come out tonight. What time is everyone going?Got to see John soon. He makes me push the boundrys a little further !LOL
LOL!!! That helps to at least be able to pick up a time slip. :bigthumb:I left at 1800 rpm instead of 3000 and didn't roll thru the light. I tried with traction control on and then turned it off and ran 12.1. So it's traction control on from now on. Now I will try to launch at a little higher RPM. They told me at the track that I need a driveshaft loop which I think is crazy. John was running 10.24 and they didn't make him have a loop but I guess the rules changed so I will go with the flow. I will tell you that after running 13.1 for awhile and to then get the HHP stage 2 upgrade done by Josh it is like night and day and a whole lot of fun now.
Whats up brother. I believe we met last night. I had the black challenger. I had a blast last night, it was my first time to the track. My son and I went just to check it out, and he convinced me to take it down the track, and now Im hooked.Heat soak!!!!! It was 37 degrees and I let her cool down a half hour before runs. I felt the intake and it was cold and my body was shaking so bad I probably shook the car loose.
LOL!!! Yeah, heat soak. LOL!!!Heat soak!!!!! It was 37 degrees and I let her cool down a half hour before runs. I felt the intake and it was cold and my body was shaking so bad I probably shook the car loose.
Nice meeting you. Luv those fog light! Maybe my next mod LOLWhats up brother. I believe we met last night. I had the black challenger. I had a blast last night, it was my first time to the track. My son and I went just to check it out, and he convinced me to take it down the track, and now Im hooked.
LOL, bro I have always had a Loop, you need one for your own saftey, everyone going down the track should have one no matter how fast they go JMO.I left at 1800 rpm instead of 3000 and didn't roll thru the light. I tried with traction control on and then turned it off and ran 12.1. So it's traction control on from now on. Now I will try to launch at a little higher RPM. They told me at the track that I need a driveshaft loop which I think is crazy. John was running 10.24 and they didn't make him have a loop but I guess the rules changed so I will go with the flow. I will tell you that after running 13.1 for awhile and to then get the HHP stage 2 upgrade done by Josh it is like night and day and a whole lot of fun now.
