1 - 1 of 1 Posts
Exclusively Available Through Modern Muscle Xtreme!
Modern Muscle Xtreme is proud to announce our co-developed, high output, single fuel pump system that can GROW with your build! As delivered, this is a simple drop-in system and requires no modifications to a factory fuel system outside of a wiring upgrade required for a high output pump. Anyone who has burned up stock wiring with other single pump systems knows that this is a requirement. Dave Weber and Justin Fore feel that this is a safety issue and feel that it should not be overlooked as a matter of convenience. To take it to the next level, parts are available through Modern Muscle and Fore to turn this into a dual pump 1200HP + system without the loss of your original investment. Its a car guy thing... 700HP is never enough, so buy your first performance aftermarket fuel pump system that can grow with your build and your budget.
Fits 2005+ LX, LC, LD
Double pump module
One F90000267 installed
Upgradeable to dual pump, external regulated
Features:
Interfaces to internal OE fuel tank connections, preserving original functionality.
Use in returnless configuration (upgradeable to return configuration)
E85 and race fuel compatible (see pump manufacturer recommendations on fuel compatibility) when converted to return configuration
O-ring feed and return ports (come with removable plugged for returnless operation)
Upgradeable to support 1200+ rwhp
NEW Anodized black for maximum corrosion resistance
NEW Polymer pump support minimizes pump noise and eliminates electrolysis
NEW Dissimilar pump compatible to minimize fuel heat while retaining maximum performance
BEST POSSIBLE VEHICLE INTEGRATION
No permanent modifications necessary to vehicle
Hermetic wire pass through, absolutely no chance for fuel smells/leaks
OEM level sender retains original position and orientation
Retains complete capacity of fuel system, even at low fuel levels
http://www.modernmusclextreme.com/p-177-hemi-single-pump-fuel-system-by-fore-mmx.aspx
1 - 1 of 1 Posts
