This is a NA build. Closed the deal with HHP Jan 31 and am getting close to the point of all parts in and ready to take car in to Charleston for the build. Very happy with the plan and scenario with Jeff approved and added to by Josh,good crew looking forward to it, should be soon now. will post updates.
HHP/BES Street Series 426 SRT-8 HEMI Stroker Short Block,K-1 forged crankshaft,K-1 hbeam rods, ARP 2000 rod bolts,Clevite bearings,forged Wiseco pistons
HHP/BES Stage 4 Naturally Aspirated Stroker Custom High-Lift Camshaft; 426ci SRT-8
HHP426SBTS Select Compression Ratio:Standard Compression (10.5 to 11.2)Select Strengthening Options:Base Motor Upgd pkg
HHP/BES CNC Ported/Polished Race-Grade Cylinder Heads Optional P/P Intake Manifold 6.1L Head Package Stage 2 Heads[
HHP/BES Ported & Polished (Interior) 6.1L SRT-8 Intake Manifold HEMI Head Bolts & Head Gasket Set
MOPAR 6.1L SRT-8 Timing Chain Assembly and ATI,Manley Perfomance SRT-8 HEMI 5/16" Pushrod SetModern Muscle 87mm TB,upgrdd injectors
Kooks SRT-8 Full Length Stainless Steel Custom Headers,Kooks Hi-Flow Catted Mid Pipes
Spec SS-Trim 900 Torque Capacity 2-Disc Mini Twin Clutch
Driveshaft Shop 1000HP Level 5 Rear axles,DS loop
Fluids,Dyno Tuned
exactly what we needed, stoked about it
Fluids,Dyno Tuned
