When I turn them on, you can hear a sound in the engine, is that normal...only happens when I turn them off and on.
It is not the in the engine. The "Clunk" you hear is a lens in the headlight that changes from low to high beam.
2021 Scat Pack 392, Frostbite Blue, A8, Harman Kardon, sunroof, Dynamics, Adaptive Susp
That or it's out of Wilkins coffee.
I heard the same sound when I rented a Mustang GT convertible out in Vegas. Gave me heart failure, I thought I broke the car and was going to have to pay money because they were going to accuse me of breaking it.
2012 Challenger SXT
I have kind of the same issue. Awhile back I installed some aftermarket headlight housing (CCFL Halogen's to be more exact). Well now when my high beams are on, it makes a noticeably loud static sound. Even though it's the same H9 bulb from factory. No clue what could be the reason. But if I look into the light just a little, I do see a spring being extended and compressed at high rates. Lights work fine so its been more of a nuisance than a issue.
There's a mechanical "shutter" that cuts off the upper beam for low beam operation and moves up in high beam mode
its an electric solenoid that accomplishes this.
the '15+ use this shutter setup whether its halogen headlights or HIDs
on the '08 - '14 LC series, only the HID headlights (projector lens & shutter) the halogen lights used a dual element bulb and conventional reflector housing reflector
if you have ignition ON (engine not running) and headlights ON and operate between low / high beam, you can hear the "clunk" sound of the shutter mechanism
(on Euro models this was referred to as Bi-Xenon (with 2 headlight layout) and really what it meant was dual mode function)
Kewl,
Hat Headgear Font Cap T-shirt
I will look into that more, thanks.
