1 - 4 of 4 Posts
Thanks for the reply and great looking hood! I have the Petty Garage set which I thought used the same base plate as the MOPAR, but I don't seem to have the threaded hole. It is kind of hard to tell, but are your lanyards running through the top grille opening hole closest to the headlights? Since I don't have a hold in my base plate, I guess I will drill a hole somewhere in some sheet metal under there and put a screw through it.
the mopar pin set, on the base plate has a threaded hole that it's attached too. the cable runs threw the grill.
here is my flickr set of my hood and pin install. the pins are lower down the list of pictures
AFR shaker hood install 2010 Dodge Challenger - a set on Flickr
TBH it's been a while and I'm currently in Vegas on business.
I believe the threaded hole is in the lower right hand corner of this picture
cables wired close up
(note dust on car was ash from a local forest fire)
1 - 4 of 4 Posts
