1 - 3 of 3 Posts
Probably should have done this before the hood was done but has anyone put pins on after the hood was wrapped?
Not interested in one's that stick on.
You do it the same way, you would have done it, before it was wrapped. If you are overly worried, use a razor blade and trim away the material where the cutter will come through.
Make sure your trimmed area is only what needs to be trimmed and will be covered by the hood pin top plate.
1 - 3 of 3 Posts
