Hey guys there is a thin rubber seal under the nose of the hood which is attached to the front bumper cover. How do you get it off? I'm trying to remove it so the vinyl wrap guy can get a better wrap on the nose. I tried to pull one of the plugs or rivets out and it popped the head off.
They are a plastic one time use rivet. You'll need to buy (pricey) new ones and the gun to install them.
Drill out the centers carefully like a standard rivet.
you can get the plastic rivets gun and rivets at harbour Fraight for If my memory is still working. you just push down on the center of the old rivet to push it through the bottom of the rivet.
Reactions: Yellow Jacket 2012
We use a scratch awl to push out the centre pin , out the tip of the awl onto the centre of the plastic rivet and just give the awl a hot with your hand or a hammer. Then pull the rivet out.
Thanks so much. Wasn't positive if they was rivets or retaining clips. So once I get them out do you think cheap retaining clips would work for the seal or put the rivets back in.
I'd put rivets back as they'd hold it in place better.
Put the rivets back
Harbor Fright POV rivet tool (plastic rivet tool) comes with 40 assorted rivets pard. # 97757 for 15.99
They sell a box of Assored sizes for 9.99 or a box of 20 with all the same size for 2.99
Once you have the tool there are many other body parts the use plastic rivets.
