Paid about $51 for the "kit" on ebay; genuine Mopar from a Chrysler dealer.
Didn't have a deep set 13mm socket, so used a 1/2"; it fit perfectly. Screwed the two nipple into the fender, the practically threaded themselves. Only caution I would give is not to over torque them.
The struts are very well marked RH or LH, popped them on the existing hood nipples and the new fender nipples with the heel of my hand.
Total 5 minutes. Probably took as long to find a box knife and open the box they came in as to install.
End result is SOOOOOOO much nicer than the cheap hood prop, and I would bet the 2 struts together weight less than the prop rod! I think I will be removing it.
Bottom line is someone at Dodge should have their butts kicked for ever putting a prop rod on these cars.
