Need advice from a brake specialist, please. My left front brake pads are too tight on my rotor and heats up really fast! In fact, it's the only wheel that won't turn freely. Should I a) bleed that caliper; b) replace the calliper; or c) try a new ABS / speed sensor? Or something else? 2012 Challenger R/T with 4-wheel disc & ABS
This has been happening for a while - ever since I replaced the ABS sensor on one of the rear wheels - but I thought it might be the caliper pin seizing, so I pulled the front calipers, re-greased the pins and painted them while they were out.
