I ordered the SRT front spoiler with the vents that throw air into the breaks. How much would it cost to install this and have it function as designed? What other parts do I need?
Speedlogix has the whole conversion kit on their website. In addition to the spoiler, you'll need the srt belly pan that has the brake ducts.
Would the new one bolt right on easily if I didnt do the conversion? Would it fit where the stock one was mounted?
How much harder is it to change the belly pan and make it functional? Is it worth it or doesnt it cool the breaks that much?
The chin spoiler is a direct swap. I can't remember if it was a direct bolt up to the R/T belly pan as I believe some of the 7mm bolts don't line up on the outside. If you're going through the trouble of the chin spoiler, you might as well get the belly pan as well.
Stevetsi said this on another forum: "if you buy the srt belly pan the holes line up and you can just use new push pins.if you just install the spoiler then yes you need to either use a rivet gun or what i did was drill small holes into the belly pan and just push the push pins in"
Speedy did this exact swap and made a video on it.
Speedy's Garage
I had a body shop do mine and a few holes had to be made and I bought the whole thing ran me about 325 for everything. The hole from what the body shop said was the air ducts and a few on the belly pan. I just bought mine for the looks but hope to upgrade my brakes and hope to notice a difference when that time comes.
· Banned
I replaced mine with a SRT front spoiler, I didnt worry about the brake ducts. Just had to drill a few holes that were in different places on the SRT spoiler. took about 45 minutes to install it.
