...and can the Diablo tuner raise the limiter?
5700 rpm seems low for a red line, as the engine still seems to be making good power at that point. I had a GTO with an LS2 that had a factory 6500 red line. Does this engine not tolerate rpm's well? Is it just cammed for torque? It seems like it should at least be able to pull through 6000 rpm without a problem. I'd like to set the limiter to 6200 and shift at 6000, if the tuner allows it. Any thoughts on that? Does the tuner allow it?
Thanks in advance.
