1 - 20 of 22 Posts
what does 3 engine builds mean? did you have to replace the engine 3 times?
The first was one of the very first approved timing chain recall at about 50k. So I took the opportunity to do the 392 Cam swap, headers etc. The second I had exhaust manifold leaks and cracked headers at about 130k, so we took the opportunity to check and replace the cam and push rods ( minor wear but we were there so might as well). The third I should have done with the second. At 160k ish liffter started making a racket. So we went in and did it all again, new lifters, push rods, springs etc. oh and of course new timing chain, guide and tensioner. How much - around $2k. She has just over 174k and runs better than new! 364 ish HP/355 TQ at the rear wheels.
2k doesn't seem to bad. Was everything done at the dealership? Wanted to get an idea of cost down the road after my extended warranty is over in 2 years
Discussion Starter · #5 ·
The installation was done at the Dodge Dealer - as I have used this one mechanic for years, and he's great. The parts are all mostly all Mopar (push Rods from, springs, seals etc. from Shop Hemi) bought myself to avoid the dealer mark-up.
your description made it sound like your engine needed three rebuilds, when actually it was:
- P01 service campaign to replace timing chain & related components. Cam swap and (presumably) aftermarket headers at the same time
- issues aftermarket headers and replaced cam / pushrods
- replace lifters due to excess noise / higher mileage wear
Reactions: SRT8outtaLA
What city is the dealership at? I have yet to find a trusty mechanic and dealership
Discussion Starter · #9 ·
Thanks Hal - the only engine failure was #3 the lifters and #2 leaky exhaust manifold gaskets (we did use Mopar) even though the headers cam with gaskets.
aftermarket headers vary in quality - some can be atrocious quality the flange and the sealing beads can make a huge difference. and quality of welds, tubing wall thickness as well
How many Mopar 10's are still out there. In February my Mopar 10 passed 10 years. Today I have 174k miles and still going strong. 3 engine builds, only the last at 166k because of any issue (lifters). Not that I would ever part with it; just curious of 250 (blue stripe) how many do you think remain.
That's a great car! I love seeing long time Challenger owners post about their cars? How's the interior holding up? Any pics?
you might want to consider having the driver's seat re-dyed and that leather conditioned. It look really dry and cracking - surprised since Katzkin leather (supplier of those covers) usually holds up really well.
Discussion Starter · #17 ·
Thanks Hall - had an interior guy treat the drivers seat a while back - probably needs it again. I bet I couldn't get a replacement skin at this point. Could always try.
They only built 500, so I'm sure there are probably still 500. Some probably have been coverd up and put in a barn for preservation.
This is an interesting and reoccurring question that I get.
Of course the answer is "it depends".
I've read a couple studies on automobile life cycles and with their results I "applied" a formula to "ballpark" the % remaining.
None of the studies of course went out as far as my chart does, so if the "rule" still applies out that far, who knows. I liked how the numbers fell with the rule. It felt real "Pareto" like to me.
I'll share it here to get your reaction.
We'll never know the exact number, but it may represent a "reasonable" approximation for discussion over beer!. So of the 250 built in this example, my chart would suggest a "ballpark" number remaining could be 208. (83% remaining)
-=PLMCRZY=-
1 - 20 of 22 Posts
