1 - 2 of 2 Posts
How can I access the fog lights from under the car? There is a plastic skirt of sorts under the front area just below the fog lights. Do I just need to unscrew those bolts that go across the front underneith or is there more to it?
It's easier if you remove the back cladding also. The back cladding is held on by 4 small bots and the front cladding is held on by a combination of screws and push pins. You'll then be able to access the fog lights.
1 - 2 of 2 Posts
