Welcome to Challengertalk. I don't believe you can retrieve a connection after you have deleted it. Looks like you are looking at figuring out how to get the XR paired. Some people have had issues I believe. Make sure you are using the precise directions. Choose your setup here:
Get detailed instructions for how to pair and sync your Bluetooth®-enabled smartphone with Uconnect® in just a few easy steps.
www.mopar.com
(If it gives you a page with no instructions, try a different browser)
See if it works. If not, you may have to try some resets on the phone
The Jeep guys are saying this worked for some
So here is what worked for me.
I "forgot" the uconnect
then shut off the bluetooth in my setting on the phone
then I shut the phone off
then phone back on.... bluetooth back on and repaired the phone with overriding the priority level in the system (she asks/prompts you if you want to do this..just say yes) and now it works fine
www.ikream.com
Good luck
