1 - 3 of 3 Posts
OK, So I bought a 6.1 manifold. It has fuel rails and injectors, but nothing else. What do I need aside from gaskets and bolts? There is a hole on the back end of the manifold where something (PCV??) was bolted on, but is not there. There is athreaded port on the front that something used to go in as well. I also need an oil cap, but I heard the RT one will work.
Who sells the phenolic gaskets?
I searched but could not find a how to article for this swap, does anyone know of one?
Guess I am going the NA route for now!!!
The hole in back of the intake is for your map sensor to bolt into.
The threaded hole on the passenger side is for your PCV to screw into.
Where to get phenolic gaskets? Try googling phenolic hemi gasket and prolly something will show up.
PWR carries phenolic gaskets.
1 - 3 of 3 Posts
