I received my stuff from AAC a couple days ago, just in time for my 10 day vacation to work on my SRTs. Below is a detailed How-To for installing Halos and includes removal of the front clip.
This first photo is before starting work. The second photo shows what the LED halos look like from AAC.
To remove the front clip, start up top. You'll see 6 pop-up plastic trim pieces with a small groove on each side. Just install a screwdriver into each groove and pop them up, then pull them out. Once you get these out (3ea per side), then just grab the trim pieces and gently pull them up, they pop right off.
Once you get the trim pieces off up top, look to the sides up top, you should find a nut on each side that needs to be removed. Loosen them with a 10mm socket, but do NOT remove them, they will be the last hardware you take off so your front clip doesn't fall onto the floor.
Next you're going to have to get under the car. I suppose you could do it without jacking the car, but having it up in the air sure makes it easier. Look at the belly pan, there are 5 small hex screws that secure it to the pan under the engine. There is also one small hex screw at each side of the belly pan. Once you get all these removed, there are two larger hex bolts that need to come off to get the belly pan off. Once you get these two bolts out, there are also three pop fasteners underneath that need to come off. I used a pair of dikes and grasped them under the head, then popped them down and off. Lastly, there are three more pop fasteners where the front brake ducts enter the wheel wells. Pop these off. Once all this is done, the belly pan should be able to be pulled off.
Next you have to start working in the wheelwells. Some have done it with the wheel on, but since I had the front end up in the air, I pulled the front wheels off to make this easier. There are several plastic rivets (5-6 on each side) that need to be pulled. The easy way to get these off, is to just use a pair of dikes on the backside and snip the ends off. Once you get the inner fenderwell disconnected from the front clip, lift up on the fenderwell and you'll see a hidden hex bolt that needs to come out (one on each side). It is also 10mm. Then lie on your back and look up under the front end and follow the flange of the front clip where it attaches to the front fender. You should find a stud that has a 10mm nut on it. This also needs to come off. The two photos below show the location of the hidden hex bolt, and the stud attached to the front clip.
You're getting close to getting the clip off now. Next, disconnect the side marker lights at each side, and disconnect the fog light electrical connectors. The harness for these lights drops down on the passenger side, then weaves across the front clip to the driver's side. Gentle pull this harness out to the passenger side. I put it on top of the engine pan, then temp installed the two large screws to hold the front lip up in place. You should be able to figure that out.
Lastly, you need to tap with your fist on the inside of the front clip (from under the car) just below and anterior to that hidden bolt that you took out of the wheelwell. Tap outwards on it and the front clip pops off the guides. Do this on both sides, and you should be able to swing the front clip upwards slightly because everything at this point should be disconnected.
Before you remove the clip, find a nice safe place to set it down. Once you get it off is NOT the time to decide where to put it. It weighs only about 35 pounds. Support it, and then remove those two nuts you loosened up. Pull forwards on the clip and it should pull off. Set it aside.
The car should then look like this.
Next remove the two bottom screws that hold on the headlight housing, and loosen the top screw, but do not remove it. If you look at the back of the headlight housing near the front fender, you'll see a metal stud that goes into the plastic fitting. There is a ball on the end of that metal stud that pops into that plastic clip. You should be able to just pull the headlight off, but I couldnt' get mine loose and had to use a large screwdriver to pry the ball out on both sides. Then remove the loosened screw and the headligths are off.
The car will look like this, and you are done with the disassembling.
IMPORTANT!! Before you cut the housing in half, use a ball-point pen or an awl to make a scratch on the large black lip that attaches to the clear lens at the four plastic webs or supports. These marking will be crucial to ensure you get the two halves properly lined up when you go to glue them back together. There are two on one side, and one on each end.
Next use a dremel fiber cutting wheel (use a new one so you have adequate depth), and cut the housing apart JUST AFT of the large black flange. See the photos below.
Next you have to disassemble the front lens assembly. This will take a total of 10 screws to disassemble each lens. The next photo shows the lens disassembled. The first two pieces you take off come off effortlessly. The third piece (the inner most piece) is wedged in there pretty good and takes some pulling and work to get out. It's hard to get out because when it was put in during assembly the thick black lip wasn't there. Takte your time starting by pulling up on the thinner side (the bottom if you imagine it installed on the car).
Continued further down in the thread...
