1 - 3 of 3 Posts
How do you remove the 4 side market lights? I want to put LEDs in them. The only thing I can see doing is prying them off... but I don't want to break the plastic lenses nor do I want to damage the fiberglass body. What's the easiest way to get them off?
Inside of each fender, there is a metal tab on one side of the side marker which needs to be pushed in to release it. The other side of the marker has a plastic "hook" which helps locate it into place. The rears are easiest, the fronts are a bit harder which can be removed underhood. Take a flash light with you.
Jack
1 - 3 of 3 Posts
