1 - 1 of 1 Posts
to do this you will need 1 small switch, 3 relays , 2 - 10K ohm resistors, 3 small diodes and 2 - 1K micro-farad capacitors
they come on when remote started if the the switch on closed and the seats stay off if the key is used to start the car
the circuit feeds a momentary ground signal to the heated seat switches during engine cranking to simulate you pressing the switch manually ... and when starting the car with the key the run start output energizes the center relay to kill the ground in the momentary circuits
1 - 1 of 1 Posts
