1 - 11 of 11 Posts
‘10 B5 R/T Classic
Hey Guys,
I installed a TSP Stage 3 Boost Cam into my R/T. I plan on writing my own start up for this cam(223/232 duration, .582/.582 lift, 115 LSA, 3degree advance and 112 ICL. Ive installed a Phaser Lockout as well.
Anyone have any insight on how to tune for a locked phaser? Disable Exhaust Phaser? What tables should i be focusing on? Ive asked on the HP forums with no avail.
Hey Guys,
Are you a relatively experienced tuner? If not I recommend getting a professional tune.
The Hemi's tune the exhaust side. You can start here table [ECM] 9442. You could also check out the HP Tuners forum one more time, you may be able to find a tune already posted to reference to get you started. There are some good sticky’s out there for getting to know the Hemi tables as well. Search for Homer's post he has some good consolidated information.
‘10 B5 R/T Classic
Im not a “professional” but i have a decent knowledge base to get me going. I’ve tuned my car for Headers and 93 already. Also Tuned a 392cam swapped 5.7 also but thats a cam thats going to utilize the phaser rather than this TSP cam thats locked out. Im gonna keep digging around. Thanks though McCloud! 🍻
Definitely dig around.... I'm in the same boat with my locked out cam. It's similar but different to what you have from TSP.
‘10 B5 R/T Classic
Discussion Starter · #5 ·
I got it figured out if you need a hand
2013 R/T
Please share? How did you come by it. Compare before and after files would be nice, attach em?
Just point me in the right direction with respect to the tables to modify. I have an idea of how I want to modify said tables. Once the phaser is locked I believe we need to set the maximum & minimum advance to 0. I could be wrong here but that’s the approach I believe should work.
‘10 B5 R/T Classic
Discussion Starter · #8 ·
So after hearing from some guys HPT forum, The logic they had was since the cam is mechanically locked, its not going to move, which i agree with. I didnt go into the variable cam tables. I disabled the phaser within the variable cam page, then set all the Part Throttle Spark and Part Throttle Lockpins tables the same. As well as set all the WOT and WOT Lockpin tables to match. I could email you my stock and my current revision if youd like to take a look
Ok, that's the same approach the Tuningschool lays out. It makes sense, I'll just have to go into the variable cam page and disable the phaser, that's super easy, thanks for posting up your findings. Most appreciated sir.
‘10 B5 R/T Classic
Discussion Starter · #10 ·
Sure thing brother,
I try to help out as much as I can. Im just fine tuning WOT and stuff for now, ive gotten PT driving dialed in pretty damn good following Tuning School approach. Do you have their book?
Sure thing brother,
I sure do have their books..... I went to the first dodge coarse they offered back in 2019. I've been tuning my car using their suggested method and the HPT forums ever since.
1 - 11 of 11 Posts
