1 - 20 of 27 Posts
Discussion Starter #1 (Edited by Moderator)
I purchased a new Dodge Challenger Widebody.Among the various packages there is no remote ignition system.Could anyone explain to me if the XBMC package (the remote ignition one) is already included in the new Dodge Scat Packs please?I wish I could clarify once and for all.Thanks in advance
Which transmission and trim level is your car?
Must have the 6-speed manual transmission as Remote Start is included with 8-speed automatic transmission on Scat Pack.
Thanks ... I have the 2020 Scat Pack with the 8-speed automatic transmission ... Does this model have the remote ignition system?
So if I understand correctly, if I have the automatic transmission, is the remote ignition package included in the 2020 Scat Pack?
Welcome to Challengertalk ;) This is an English language forum, please continue to post in English only, thanks
Yes, that is correct. With A8 automatic, the remote start is included and you should have it.
To understand better and definitively ... Is the remote start system included in the Dodge challenger 2020 Widebody if it has an 8-speed automatic transmission? Thanks so much for your assistance
2017 T/A 5.7 A8 front and rear strut braces frame connectors
No automatic start for any vehicle that has manual imagine if you forgot to leave the car in neutral and then the next morning you hit the automatic start button and the car drove through the side of your rear house
You can buy the mopar keys on amazon mopar banded not some brand X but you still have to bring your car to the dealership to have your new keys to have them re flashed
Look on your window sticker, it should be listed on it.
its an option and most likely cannot be added as an accessory
need last 8 of the vin number to verify
With the vehicle should be a large sheet of paper (monroney sticker) that was attached to either front side window and lists everything on the vehicle. I’d think with the auto trans it would come with the car, do you have a sales brochure, everything should be laid out there too.
Discussion Starter #17
Yes, I have a brochure, but there isn't the remote start system from the packages... Thank you for help
The offer above from Steve White motors is as good as it gets here. Luke will get you the most accurate answer there is. I wouldn’t be hesitant to give him your serial number.
in the past, remote start as a factory accessory for 6.4 was not available
unless installed at the factory
1 - 20 of 27 Posts
