Maybe I'm crazy but I was out driving for quite a while, the entire engine bay was heat soaked, yet the throttle body was COLD as ice.. As was the airbox and the intake plenum. I can't see how putting a piece of aluminum under the hood that is going to absorb heat and suck hot under hood air will be good for this engine.
I don't know if any of you have opened your air box yet.. But check this thing out!
There is no "resonator" under the air box, it draws air from the bumper which is sealed off from hot under hood air. Actually you can see the brake cooling duct by looking through the bottom of the airbox.. If anything, I think it would be easy enough to hook up a hose from the brake cooling duct to the bottom side of the airbox.
Thoughts??
Thoughts??
