Hi all,
Installed the 91 tune and all was well the first couple of days. Total all the warning lights are coming on (ESP/BAS/ABS/Traction control). I put back on the stock tune but still the same issue. Anyone experienced this before or have any suggestions for me to correct fix?
I tried also to clear all the diagnostic codes but there were none.
Any help would be appreciated. Thanks.
pull the battery off for 15 min and let it reset to see what happens
could be the abs/traction fuse under the panel under the hood also
Well I tried it and no luck. I checked all the fuses and disconnected the battery for 30 mins. When I put humpy dumpty back together again all the warning lights are still coming on. Any other ideas to try before I take it into the dealer? I have an appointment for next Tuesday.
I thought you couldn't tune these cars anymore unless you got a unlocked pcm?
the '08 - '10 PCM (OP has a '10) don't require an unlocked PCM.
Similar to the '11 - '14, tuners figured out how to get around encryption.
With '15+, those required unlocked PCM - these have a different protocol.
