What can I use on the inside of my srt wheels to keep them from getting filthy from break dust and road grim
What would you guys recommend for the wheel wells?
I've tried some grease cleaner on my other car and it was too strong and the plastic kinda faded.
Something that will remove stains and burned rubber that's stock to it.
I've always used generic brake cleaner and put an old sock on her hand and just rub on the inside of it to wipe away grime on the inside of the wheels. Works amazing.
I use Aerospace 303 for the wheel liners - a few applications and the stuff lasts.What would you guys recommend for the wheel wells?
Well I know the inner part of the classic wheels aren't exactly shiney anyway. I use a brake cleaner that foams up when spray it out of a can and I just smear it on and it's so easy to remove grime. I only do it when I rotate tires when the wheels are off obviously so not done very often. I'm just careful not to get any on the outside of the spokes where it's clear coated and polished and all that.
Adams makes THIS specifically for wheel wells.What would you guys recommend for the wheel wells?
