1 - 10 of 10 Posts
Finally got around to installing one. I bought the Veckle Mini 0906 dual dash cam because it has quite good vid quality for its price point.
Also works with dashcamviewer.
977011
Here is a snapshot from dashcamviewer---Front camera.
977012
Here is a snapshot from dashcamviewer---Rear camera.
977013
It also has a "park guard" mode but I am still waiting for the hardwire kit for it. Anyways, the reason I decided to install the cameras (literally only took 1 hour to mount the cameras and snake the rear camera cable to the front camera) is because there are way too many knuckle heads on the road besides me. The cameras are so small you can barely tell they are installed from the outside. I have the rear camera mounted on the 3rd brake light cover to avoid the electric heater lines and the front is mount in the center just behind the rear view mirror but just low enough to see the little LCD screen. I'll post some more pics of the install when I finish the hardwire kit.
Discussion Starter · #2 ·
Here are some pics of the install.
Front cam - outside
977014
Front cam - inside
977015
Rear cam - outside
977016
Rear cam - inside
977017
Thanks for that write up. Did you tap in to the rear view mirror for power?
On a scale of 1-10, how difficult was this to install? I can't handle anything above a 5 in difficulty. :(
Discussion Starter · #4 ·
I have not received the hardwire kit yet so currently just plugging into the passenger cig lighter socket. My plan is to snake the hardwire through the driver A pillar where I can tap power from my gauge pods that I installed a while ago. If I did not have the gauge pods I probably would have snaked through the passenger side A pillar, and find a grommet on the firewall that I can pass the cabling thru into the engine bay. Once in the engine bay I would use the provided fuse tap. I'll give more details when I actually hardwire it.
Hardest part about the camera install is running the rear camera cable. I just popped off the passenger A and B pillar covers and used a fiberglass rod to snake the line through. I started from the passenger side window seal, snaked the rod until it poked through the B pillar, taped the rear camera cable to the rod, pulled it through, and hand snaked the cable past the A pillar and finally all the way up to the rear view mirror. There is a lot of excess rear camera cable which I stowed in the B pillar.
I would give the difficulty level a 2 only because snaking cables through the car can be a PITA.
Discussion Starter · #5 ·
Just received the hardwire kit. It consists of 3 wires, constant power, ACC and ground. There is a module that converts 12V to 5V but it also detects when the car is running or off (via the ACC line) to tell the camera when to engage park guard mode (basically a low frame rate recording mode). The module also has a 4 position switch that allows you to select the min voltage to kick in battery save mode (i.e. turns off camera park guard if battery voltage gets too low).
I decided to tap in directly to the 12V power outlet harness.
977136
Why? Because it contains all 3 connections I need and it is fairly easy to get to. Just need to add 5 amp inline fuses to the module lines, snake the micro USB connector up through the drivers A pillar and call it a day....is it Saturday yet?!
977131
Discussion Starter · #6 ·
Well it is finally hardwired in. What I like about this set-up is if I don't want the camera to record in parking mode I just slide it out of the GPS mount and lock it in my glove box.
BTW here is a PDF providing some more wiring details.
I run commercially with a 2018 RAM 4500. I bought a Garmin dash cam a few years ago. You are right when you say there’s plenty of knuckleheads on the road.
Here’s a link to one of mine I saved.
Some nice pucker factor there, well they guy didn't stuff it into anything, I bet he had a hell of a time getting out of the median.
Discussion Starter · #9 ·
Really digging the timelapse setting on the dash cam. Captured some cool cloud movement while the car was sitting in the parking lot at work.
2019 SXT Blacktop in Triple Nickel
After over a year, how is the dashcam doing?
1 - 10 of 10 Posts
