What are people using for a slave cylinder when they put in a high performance clutch, go with stock?
Go with stock
Reactions: AirborneSilva
Thanks Champ!
No worries
I have one as well.
You have a lift or on jacks? Grease up the input shaft lightly it is a pain.
Also
My bell housing for some reason from the factory the dowl pins that are in there, they drilled it all the way thru and mine pushed out and went for a ride inside so take a look at yours. IF IT IS THE SAME RED LOCTITE THEM IN
Discussion Starter · #5 ·
It's at a friends shop up on a lift, he does charge me a little bit and helps out some but it's a shit load better than laying on my back. This is actually the second clutch I've put in, the other was a little over a year ago and has only just a bit over 5,000 miles on it. I will never buy anything that Holley sells again, the piece of crap clutch was a pain from beginning to end! Last time I did buy a Lake bell housing, kinda had to (long story), but now it's safe encase the clutch ever comes apart :oops: also put a driveshaft loop on it. Thanks again!
2014 Challenger SRT 8
U have to BREAk the clutch in, at least 500 miles. Seen so many clutches fail do to this not being done...............
Discussion Starter · #7 ·
I did drive it easy for quite a few miles but this is direct from their website "No break in period – Install the clutch and drive it! " I don't beat on my car a whole lot, certainly not like others I've seen. I am running 580 HP and 565 Tq at the wheels but this clutch is supposed to handle quite a bit more!
Stock. You're not going to believe the way it grabs once it's in. I believe it's rated at 1,000 whp. I have a about 60 more than you right now, but I'm hoping to have 800 whp once I get my boost fixed, so we'll find out what it can handle.
Discussion Starter · #9 ·
Thanks Brother (y)
Reactions: Gila Hemi
