1 - 20 of 21 Posts
Sorry if this belongs in the R/T section ..............
The R/T emblem that I ordered (part # 4806323AB) will be arriving soon, so wanted to see if anyone has any advice/lessons learned/etc that I should take advantage of when installing it on my rear spoiler ................. such as :
- mounting it straight/level
- good adhesion
- left-to-right location (ie just left of the right-hand-side trunk seem)
- other ?
I have a 2010 Detonator Yellow R/T with a black spoiler.
Thanks
just my two bits having done a few...
#1. clean the area where the emblem is to be mounted with windex, simpe green or similar, then again with rubbing alcohal to remove any & all wax, grease, dirt, etc.
#2. I used painters tape to lay down a straight tape line where the bottom edge of the emblem should be once mounted. stand back and look at the tape line from several angles to make sure thats where you want the emblem and its not crooked, canted or what have you. You could use a small bubble level to confirm tape line is straight, but most tiems can be done by eye. The tape is easily adjusted/removed and will serve as the margin or guide for final install.
#3. a little bit of sunshine doesnt hurt..warms the plastic spoiler and will help with a bit faster adhesion.
#4. peel n stick. hold in place for a few minutes and you should be good to go.
Look closely at pictures. I'm on my second HC badge as I placed the first too far right, and too low.
Tape can help, but a bunch of the Mopar badges have this big foam block that surrounds the emblem, which makes lining up to a tape line more challenging.
Yes, clean the surface well.
Check out my " Garage" section for pics. I have pics of both my "DY" RT and my SP with their RT badges and placement.
IMO, I like the edge of the "T" lining up with the trunk lid edge.
Used the eyeballs with a steady hand to install.
Good luck.
Take your time, eyeball it, temporarily tape it in position, repeat until you find the desired placement. I used a small level to place a strip of white artists tape above the R. I preferred it away the lid edge, I have an '18 RT so I'm sure your spoiler will have different size/shape.
+1
I placed 345 HEMI badges on my Ram 1500 in place of the 5.7 HEMI. I did it just like this. Took my time. It turned out well.
Not there!!! >:)
Looks great :wink3:
Discussion Starter #14
After the install, I realized just how concave the spoiler surface is. Are they "all like that" (in the 2010 era) ? I'm the 2nd owner, so not sure if the spoiler is 'factory' or not. (My equipment list says "MXXS Rear Bodycolor Spoiler")
Seems like this is gonna affect the adhesion.
If you cleaned the area well, and pressed the emblem down well, you shouldn't have any issues.
My "DY" spoiler had the matching body color. IIRC, the SRT's had black spoilers. Both are concave, and so is the spoiler on my SP.
Tons of high pressure washes and the RT is on as tight as ever.
Discussion Starter #18
After a week or so (of mostly sitting in the garage due to weather, etc), I noticed the emblem was just barely clinging to the spoiler ........ just at the top and bottom of the letters. So I removed it. And lets just say there was not much messy "goo" to remove from the spoiler.
The part I purchased (on ebay) was OEM, came in a sealed OEM bag with OEM part #, etc, so I trust it was OEM.
So either I did not clean the spoiler well enough before installing .............. or perhaps the emblem was so old that the glue had deteriorated ? Or other explanation ?
I really liked the look, but not sure if I want to give it another try.
I own a sticker/sign shop and have been in the biz for 40 years and you are spot on...
I cleaned the area well. Then I used blue painters tape to space the right side of the RT emblem the width of the tape to the left of the trunk lid. Then I set the emblem on the spoiler and found that the emblem was flat and there was a curve to the spoiler. So I pre-bent the emblem to try and match the curve. Then I used a level on the emblem and removed the strip. Then attached.
I too looked at several pictures of others and just chose the location that I liked best. Using the blue tape allowed me to make changes to the location until I was happy.
1 - 20 of 21 Posts
