Has anyone seen this kind of problem on there instrument gauges. I have a 2010 Srt8 with about 70k miles and these black looking moisture spots came out of no where. Can any put there input on this? Thanks!
1015056
2016 R/T Scat Pack
YUP, had 6 failures in my old 2010 R/T, two were bad right out of the box. Thankfully I had extended warranty. It's an $800 job. The whole cluster has to be replaced.
Reactions: 19johned53
2016 R/T Scat Pack
😣 thanks
Yeah it's a printed sheet, there are no bulbs to replace. Two of my failures also had the odomter, temp, gear position flickering in addition to the black spots :confused::mad:
Discussion Starter · #7 ·
It's the EL (electroluminescent) foil built into the back of the cluster and needs to be fixed by professionals. If you remove the cluster and ship it off it's about a $250 dollar job which is only 1/3 the cost of a replacement unit.
For mine it seemed to get worse with the colder weather until I had it repaired by InstrumentClusterStore in PA. There was another highly regarded place in NY (the name is escaping me at this time) but they had a backlog of work at the time with a much longer wait.
